Moe Maishlish
- Mar 30, 1999
Hi all,
I'm looking for help trying to fully configure my RCA 2.4 GHz Wireless Video Sender units. It's used to send the signal from one television to another, without the need to run wires. I'm currently using it with my satellite system, to send the signal from my main TV to that in my bedroom (http://www.rca.com/product/viewdetai...20015,00.html?)
I bought this unit and it came without the manual. I've already e-mailed RCA to see if they can send me one, but I don't expect a very prompt response. I also checked their website for support info, but it's turned up squat!
Like with all these units, you are just bascially sharing the original source signal on two sets. The benefit is that I don't need to buy another reciever... but the drawback is that I can only watch one channel on both sets at the same time (which is fine, considering I live alone, and wouldn't need to watch both at the same time anyway...).
In any event, I've hooked up the transmitter & reciever, and the audio & video are transmitting just fine. The problem I'm having is getting the remote control to work from the 2nd TV in the other room, where there is no reciever. The RCA Reciever Unit is supposed to accept the remote signal, send it back to the transmitter, and control the reciever.
There is an LED connection & cable which I have not connected yet, mainly because there's no LED connection on the back of my reciever. Is this the problem? Does the LED need to be connected?
FYI, I have the Bell ExpressVue reciever, Model 3100 ([http://www.futureshop.ca/catalog/pro...D78468EB743F1C).
Right now I'm stuck walking back to the main TV to switch channels. I'd appreciate any help that anyone could provide!
Thanks!!!
Moe.
I'd appreciate any help that anyone could give me.
Thanks!!!
Moe.
