Howdy all!
It has been years since I have upgraded any of my home theater / television setup. I am currently running on a Mitsubishi 65" Diamond projection TV, a 1/2 way broken Yamaha receiver, and Boston Acoustics bookshelf style speakers + PV600 sub. I am going to upgrade, but need major help. Analysis paralysis is killing me, and I need some direct feedback based on my room, etc.
I need assistance with the sound equipment.
Please help!?
Room:
Basement entertainment room. It is a 12'.2" x 26' base room that "L" shapes off to a small hallway that leads to a bathroom and office. The main carpeted area is 12'x15'. There is a wet bar with tile that takes up the back 10' of the room (with cabinets, sink, etc). In the walls are pre-wired audio cable that allows for a receiver up front and connections to high-wall placement for a Front, Right, Rear Left, and Rear Right. These mounts are on the 4 corners of the 12'x15' carpeted area.
TV:
I have purchased a Samsung 75" UN74F8000 LED/LCD TV for the room.
Audio:
Need help! Due to the wiring setup, I am going with a 5.1 setup. I need the following:
- Receiver
- Front Speakers
- Center Speaker
- Rear Speakers
- Sub
- BlueRay player
Budget:
Would like to be around $3,000.00 - $3,500.00 for the hardware.
Other info:
- I need a stand of some sort for the TV, receiver, center channel.
- I also don't mind Floor standing front tower speakers (don't have to use the high wall mounts).
- I want hardwired speakers (no WiFi), unless someone can tell me why it would be worth hanging extension cords for the rear speakers.
Purpose:
- I watch BlueRay Movies.
- I stream NetFlix / Hulu+
- I watch live action sports and Cable TV shows.
- I like to watch action movies loud and feel like I am in the movie.
I have talked to random people, and have been told to go the Paradigm Studio 60 Fronts / CC590 Center / ADP590 rears; that gets expensive fast. Is it worth it for my needs? I am not some audio geek that even knows the sound difference between a mid high, mid low, etc. Things go boom, and I want to be in the movies if I can..
If you had a $3k to $3.5k check for this hardware on a room like I described, what would you buy and why? I would like to purchase on Monday, but don't know what to do.
Mike
Please help!?
Room:
TV:
Audio:
- Receiver
- Front Speakers
- Center Speaker
- Rear Speakers
- Sub
- BlueRay player
Budget:
Other info:
Purpose:
Mike
