Hello all:
I have a pair of original Titanic 1200 subwoofers that I have been running sealed (2.2cu ft) for a couple of years. They were great when paired up with a pair of small two ways. Now I have incorporated a pair of Martin Logan Sequel IIs into my home theater and the Titanics are kind of redundant. So I was looking at the original datasheet for the Titanic 1200 and saw that there was a plan for a 3.7 cu ft vented isobaric design that is tuned to 17hz. Going to a vented isobaric design seems to be the only reasonable way to get these drivers to reach lower and not end up with two crazy oversized subs in my living room. The thought is to build the isobaric sub into a custom entertainment console that will replace the stand for my Samsung DLP as I also want to clean up the wall with the home theater equipment - less boxes and cables running everywhere.
I did some modeling myself using the free program from AJ Design and I am coming up with a similar volume for an SBB4 alignment, but closer to 4.75 cu ft for the QB3 or SC4 alignment. With the latter alignments I am getting a 4" port length of about 22-24". Inside dimensions of the current idea are 33" x 20.5" x 15". The port will have to make one 90 degree bend.
I was hoping somebody with more experience and a different modeling program like WinISD (I can't figure that one out to save my life) could give me a sanity check here. I don't really know what to expect when choosing SBB4, QB3 or SB4 alignment in this AJ design program. Why is the SBB4 alignment choice coming up with the smaller box volume, I thought it was supposed to be the other way around? Is 17hz too low to try to tune this to?
Here's some pertinent info:
Receiver: Onkyo with LFE output (60,80, 100, 120 hz settings available)
Subwoofer Amp: Behringer EP2500 with FBD
Drivers: 2 original Titanic 1200 (4ohm, Fs=16.26, Qts=0.407, Qes=0.428, Vas=280.16L, Xmax=14.22mm
Thanks for any input!
