Need Denon 3802 help! (1 Viewer)
Brett Nix
Has anyone ever experienced a volume loss with their 3802? Over the past couple of months it seems to require turning the volume up significantly more to achieve the same volume level. In the past, watching Shrek with the receiver volume set around -30db was plenty; now we need to go to -20db for the same volume level. And it's even worse with the CDR/Tape inputs where I have run my Roku Soundbridge. Any suggestions?
EarleD
CT
Earle Decker
I use to own a 3802 and never had this problem. The only suggestions I have is to unplug and replug in all RCA connectors. Check to see if your compression setting(night mode) was turned on.
mycuu
