The setup is a Yamaha RX-V385 5.1 with Klipsch R-25C center, R-41M bookshelves for front and sides and R-100SW subwoofer.
The setting is a rectangular 12x28 living room with the tv on a short wall, close to the corner and the usual sitting area diagonal from it, on the long wall.
The mood is a playful dog, so I need to mount the speakers ~ 5' or more up the walls and use some wiring channeling to keep the wires safe.
The question is how should the speakers be mounted to the walls? And are the positions shown in the pic impossible? The gray wall is "open" to an open concept floorplan.
- Install small shelves for each speaker and plunk them down?
- Install brackets (like angle iron) for each one?
- Something else?
- Solid mounting or something resilient like a rubber mat?
- Something else?
