TheAmericanStig
- Jan 25, 2009
- John
Mods, please feel free to move this to another area if it's wrong here - but my topic mostly revolves around speakers.
I'm currently running a Mitsubishi WD-57732 (57" DLP w/ 1080P capable). I haven't tuned nor tweaked the set yet, it's a few years old now. Also have an old JVC Rx-6008V powering a Frankenstein-type setup comprised of 2 Bose fronts and an off-brand Center. This is the living room setup. TV is going downstairs (soon to be the den of sorts), and a new audio system will be put in place.
Area is a cornered-off section, with no limitations on where to put things. TV could go in corner or against side of wall. 1/2 of basement where I will have the setup is 19'x15.'
Primary purpose will be TV, Gaming (on XBOX360 running component), DVD, (now on 360, soon to be Blu-Ray), and occasionally music (moreso if it sounds good).
Budget was initially under $1k aimed at a HTIB, but considering how long I will keep it, (longer than my TV), I'm willing to spend between 1500-2500 for a killer setup that will sound great with Halo or GTAIV, any Blu-Ray, and even some Tiesto
Heard the Paradigm Cinema 110 L/Rs with similar centers and rears powered by a Yamaha RX-V663 by recommendation at a trusted retailer. Sounded good, but considering a bigger/badder setup. I was looking at Klipsch, specifically the RF-52 setup. Friend and techie recommended Paradigm's MiniMonitor or Atom Monitor series, powered by Onkyo TX-SR806 or if budget allows the TX-SR876.
I'm trying my best to as much research as possible. I'm more familiar with the specs of guitar amps/speakers and cars than I am home theatre/stereo.
Appreciate any feedback you guys can give.
