SgtSaurus
- Jun 30, 2016
- Andrew Filicky
I'm not sure if this is in the right forum, but I'll still list my problem. I have a JVC TH-G41 hooked up to my XBox One through optical and no matter what I do to reset it it will work for about thirty minutes then start blaring static. I can change inputs, but after replugging the TOSLINK in it doesn't fix it. The only thing that resets it is unplugging and replugging the system in multiple times otherwise just powering it off and back on makes it not register any optical input.
