Got my XPA-5 last night and hooked up 3 of the channels (fronts and center), popped in Dream Theater: Breaking the Fourth Wall concert bluray, and after a few minutes, the amp shut down. I removed the center channel from the amp so it's only driving my fronts and everything seems to be okay, even at very high volumes. It appears that my 20amp dedicated circuit is insufficient. I have the following equipment plugged into a CyberPower CPS1215RMS rackmount PDU (15amp 1800VA)
Pioneer Elite SC-95
Emotiva XPA-5
LG Bluray player
Roku 3
Verizon FIOS box
Sewell Direct BlastIR
Netgear Router
2 Servers (Intel-based) + 2 monitors (FreeNAS and NAS4Free)
TP-Link 24 port gigabit managed switch
Heh, as I typed the CyberPower sentence, I realized that THAT is probably my culprit... (although, 20amps may still be insufficient) It only handles 15amps and I'm pumping a ton of power-hungry gear through it to a 20amp circuit. I did some quick math and that Emotiva draws between 10-15amps by itself. I've got another 15amp circuit nearby that only has my projector on it. I think I'm going to add another PDU and move my servers and receiver onto that... Or, if my electrician used 12gauge wire, maybe I'll swap out the 20amp breaker with a 30amp and buy a new PDU that supports that!
More importantly, and of more interest to you guys (most likely anyway) is how awesome the Emotiva is. After I dropped it to two channels driving my fronts, it hummed like a bird (figuratively. If it makes any noise at all, which it doesn't, I wouldn't know because it's on the other side of a sound-deadened wall). The Pioneer Elite SC-95 that used to drive all my speakers sounded okay, but after hooking up the XPA-5 the sound was so much more crisp and clear. I've never owned a separate amp before and I have to say WOW! I didn't expect to have such a marked improvement in sound quality. I figured a modest one at best. In addition to the sound quality, cranking up the volume is well supported. My Pioneer would shutdown (in surround mode, in stereo mode it was fine) when cranked to -10dB. The Emotiva doesn't even blink regardless of sound mode.
Bottom line, I love it driving two channels. This amp has earned 4 out of 5 Giggities from me. Once I sort out my power issues and have all 5 channels going, it's sure to earn that 5th Giggity.
Pioneer Elite SC-95
Emotiva XPA-5
LG Bluray player
Roku 3
Verizon FIOS box
Netgear Router
