Dan J
- Jul 14, 2005
Ok, decision time is here. I was ready to buy the Sony MF750H speakers until I heard the JBL's. The Sony's sounded fine until I heard the JBL's. Then I realized that the Sony's weren't as clear and that the E80 or E90 are worth double the cost and will be purchased.
Unless.
I would hate to buy these and find out tomorrow that I should have bought something else. So, can any of you audiophiles recommend something better? Price wise the E90's are about $225 each, and that's my limit. I'm sure that someone will suggest that I should save up and buy something that is only $300 more, but I can't. I can either spend the cash now or kiss it goodbye. If you're married I'm sure you understand why; if not, count your blessings :wink:
Anyway, the E80/E90 set and EC35 center speaker will be purchased tomorrow unless I'm making a mistake. Am I?
Thanks folks,
Dan
Unless.
Thanks folks,
Dan
