JosephCon
- Aug 26, 2003
I just purchased a Toshiba 42HDX82 Cinema line series set and had it delivered today. I have it hooked to normal cable and to DVD via component outputs. When I view it from any source (cable, DVD, etc) it appears to have two horizontal lines on the top and bottom, almost where you would expect to see the black bars from a widescreen picture.
I tried setting the screen to different aspect ratios and it still looks the same, and on 4x3 ratio you can noticeably see the lines in the grey area of the vertical lines it adds. Anyone else seen this kind of issue? Should I return the set?
