Chris SS
- Jun 7, 2003
First of all I would like to thank everyone for their informative posts here at HTF, a truly invaluable source of information.
After reading many comments here and other places regarding the Infocus X1, I chose it as my very first projector. Out of the box I was impressed - vibrant image with very good detail - but then...rainbows.
I stuck with it for a few day - adjusting settings, which did lessen the rainbows a little, but they were always there - I was starting to get headaches and really couldn’t watch a movie in comfort. My wife and friends also seen the rainbows and although distracting to them, they didn’t get headaches.
All I can say is that in my book DLP is a none starter. If you don’t see the rainbows (lucky you), and you NEVER plan on showing movies to anyone else then it’s a great product, but if others are going to be guests to you screenings - some of them will always see rainbows.
So it was good buy to the X1 (sorry Infocus), and hello to the SANYO PLV-Z1.
I was worried about screen door effect and image quality of LCD, but it was my only real choice after DLP. The Sanyo is a great projector, that delivers a superb image. Screen door isn’t visible at normal viewing distances, and image quality is spot on and of course no rainbow problem with LCD.
So the Sanyo is a keeper- my family and friends can watch big screen movies in total comfort (and no headaches). Thank you Sanyo for making a great home theater projector.
Enjoy,
Chris.
:star:
Edit:June 13 2003
Just installed a Toshiba progressive scan component output DVD player. This increased both contrast and detail. Used Se7en DVD as a test movie - Dark areas are much better defined with better detail in shadows. Lighter scenes are very sharp and detailed with rich vivid colors.
If you are serious about FP then you should go with component input, it really brings out the best in the source material. Very Recommmended.
Setup so far:
Projector: Sanyo Z1 (on home-made ceiling mount) $1499 (inc 2nd bulb)- projectorpeople.com
DVD: Toshiba SD3900 $99 - Best buy
Reciever: Kenwood Dolby/DTS Digital 100 Watt X 5 $160 - Best buy
5 Sony Surround speakers (already owned)
Sub: KLH 100 Watt $89 - Best buy
Screen: 41" x 83" White flat wall,with home made black cloth frame - $2 Wall-Mart
As you can see this setup was made on a budget, and as my first true home theater, it rocks pretty good ! I love it.
Enjoy.
Chris SS
Enjoy,
Chris.
:star:
Edit:June 13 2003
Setup so far:
Enjoy.
Chris SS
