Isn't a normal Non-HDTV 530 lines of resolution? If so, why is it measured in 480? Like, 480i?
Jan 12, 2003 #1 of 4 NickSchmidt Agent Joined Feb 12, 2002 Messages 49 Isn't a normal Non-HDTV 530 lines of resolution? If so, why is it measured in 480? Like, 480i?
Jan 12, 2003 #2 of 4 Kevin P Screenwriter Joined Jan 18, 1999 Messages 1,439 It's actually 525, but 480 is the number of lines used for actual picture information. 45 lines are reserved for blanking, closed captioning, etc. info. KJP
Jan 12, 2003 #3 of 4 NickSchmidt Agent Joined Feb 12, 2002 Messages 49 If you use an S-video or component cable does it use up all the 525 lines or still just 480?
Jan 13, 2003 #4 of 4 ManW_TheUncool His Own Fool Premium Senior HTF Member Joined Aug 18, 2001 Messages 11,980 Location The BK Real Name ManW The actual # of lines used depends on the source content, not the video connection as long as the connection adheres to NTSC standards. _Man_
