shredhead1260
- Dec 5, 2020
- Jason
I just got an 82 inch TV and would like to investigate how to get some decent sound to go with it.
The room has windows and a fireplace on one side and is partially open on the other side and also open in the rear where the kitchen is. So it's not a fancy home theatre system that I'm after, just some decent sound that one could hear in the kitchen if they happened to be cooking or sitting at the table.
I am hoping to be able to leverage existing built into the wall rear speakers. These are wired to the wall where the TV is. In my research thus far it seems like using those speakers in conjunction with one of the various sound bar packages out there will not happen. I currently have the rear speakers powered by a Carver amp / pre-amp tuner which is from the 1990s. I used a converter to get the optical cable to RCA's, then to the back of the preamp - to me it sounds good. But that's not surround sound, that's just stereo sound behind your head.
I'm not against ditching the Carver stuff and getting a new modern receiver, then new front speakers (left,center,right) and a sub. I was just hoping there might be some easier way. Due to the acoustics of the room, spending big money would not make sense. I have not seen anything yet that seems to fit the bill, but perhaps I have not been looking in the right places yet.
