mckenzig
Grip
- Oct 13, 2003
I'm building a new HTPC to connect with my InFocus X1. My question is, what is the best way to connect the HTPC (ATI Radeon 9600 Pro) to the X1?
I was thinking of using a long monitor cable to attach directly to the VGA port - or I could use the VGA-Component break-out cable and use a longish (16ft) component cable.
Which connection would be better, or would it make any difference.
Cheers,
Grant
Cheers,
Grant
