Mike-Gr
Grip
- Feb 22, 2006
I just received my STF-2 the other day and am ready to calibrate my speakers and subwoofer and need some help with the initial settings for the STF-2.
My main question is what should the controls on the back of the STF-2 be set to initially. Controls are:
Phase switch: 0 degree or 180 degree. Should this be set to 0 degree
Volume: Probably set to 1/4 or 1/2
Crossover Frequency: Should this be set to what my A/V Receivers crossover is set at (i.e. 80hz)????
Crossover switch: Out or In. If set to Out the crossover is controlled by the A/V Receiver, so the crossover frequency dial would not be used.. is that correct???
I have the sub hooked up via the Sub In (LFE) connection.
I have my Avia disk and Radio Shack SPL Meter ready... so any help would be appreciated.
