Have outdoor speakers wired to a receiver indoors, that's about 30 years old.
I would like to use my iPad and/or Galaxy tablet while I am outdoors on the patio (in range of the indoor receiver) to stream whatever music I select to that receiver.
I used to have an Apple product (think it was the Airport) that wired into the stereo and allowed Airplay, but it was so "wonky" and often disconnected that I ended up throwing it out.
Don't want to spend a lot of money. Would rather use a WiFi device than Bluetooth.
What would you recommend? Apple compatible is preferred but if cheaper, I would gladly go with an Android compatible device.
