hi again techie friends i own an azur 752bd , np30, 551r with MA bx2's bx centre and 2 x ca minx min21 at the rear for mysurround sound/hifii solution with a 60" samsung 3dtv 1080p and was wanting peoples opinions on the best way to connect these seperates together.
i dont use the streaming function on the 752bd i prefer to use the np30.
i want to get the best out of my music/movies audio.
the bd player is running through the amp and so is the np30.
for example should i connect the np30 to the 551r amp or run it through the bd player?
obviously the bd player has 5 dac's thats why i ask.
"there are not one but two HDMI outputs, ..., but only the primary output (HDMI 1) benefits from the on-board Marvell QDEO video processor" what should i connect to hdmi 1 and what should i connect to the mhl hdmi socket?
"the Cambridge Audio Azur 752BD can actually be used as an AV hub, allowing other devices to take advantage of its high-quality upscaling and upsampling". should i use the bd player as the hub or use the amp i think im using the amp at the moment.
"there are optical and coaxial inputs and outputs..., and a separate set of analogue stereo outputs for two-channel setups". should i run my front speakers through this instead of the amp
here is the review where i got my info
Read more at Cambridge Audio Azur 752BD review - Blu-ray player reviews
any advice would be greatly appreciated, thanks in advance Steven.
