Dave Lemasa
- Mar 17, 2014
So I have two beautiful Mirage towers that I need to get out of the living room for space reasons. I'm currently running 5 HDMI devices (1 cable box and 4 VG/BR consoles) into a Denon AVR-2113CI and then single HDMI into my TV. I'm unable to run a true HT set-up due to space, etc. I bought a Speakercraft CS3 as a replacement, but one of the drivers is "popping" - A LOT. I'm returning it.
I'm shooting for the best simulated surround possible with about a $400/500-ish budget. My goal is to basically run my receiver into a soundbar *if that's even possible*. The problem I keep bumping into is everything is Digital Optical/RCA input and I can't seem to find an HDMI "passthrough" solution whereby I could connect my receiver via HDMI to a soundbar, which in turn could run another HDMI into the TV, effectively running audio into the speaker while letting the video go to the TV. Ideally, I'd like to find something that will allow me to run discrete channels into it via speaker wire, but I'm imagining that's expensive.
I'm considering getting a ZVOX, but again, the input problem. Anyone have any recommendations? I have found some soundbars that have HDMI in and out, but they are Sony/Samsung and I don't know if the quality is there. Bottom line, I'm hoping to avoid settling for just running an optical cable to the soundbar from the TV because of the TV's lack of dts, Dolby, etc. processing. If I'm forced to do that, what are good options (soundbar, pedestal, etc.) for simulated surround?
Edit: My TV is a Toshiba that outputs Dolby Digital and PCM via the optical out.
Thanks!
Thanks!
