Matt AR
- Jan 16, 2002
Hello,
I just took delivery of the 57TWX20B yesterday and I am having a few problems. First of all I have 3 "dim" spots on the bottom of the screen. The first is centered directly on the bottom edge, about 2 inches long and half an inch tall. The other two are about 6 inches to the right and left of the first spot, about 1/2 inch tall and 1/2 inch wide. You can only see these spots when directly centered in front of the screen. You cannot see them when at an angle to the tv.
The second problem is with calibrating the television. I used the Sound and Vision disc to calibrate after letting the television warm up for a few hours. I then proceded to watch LOTR. I began to notice that all deep blacks had a red tint to them. The only way I would get rid of this was to change the color setting to "High" from "Standard". Is this normal? I was under the impression that I should avoid the "High" color setting.
Any and all help would be appreciated...
Oh, I am using a Sony DVP-S530D DVD player connected by component video cable.
