SteakTheCow
- Mar 6, 2016
- Mark Sherman
Hello all! I'm new to the forums, and I'm looking for some assistance with an setup issue with a new-to-me receiver.
The offending receiver in questions is a Denon AVR-988. Obviously this is an older model, but it was nice enough for it's time and it *should* be functional. My problem is this: the only audio that is outputting from the unit are the FR and FL channels when playing out an analog source set to stereo/direct. There is no audio from the subwoofer (despite it being set to on for 2ch/stereo), and when I switch to any available surround mode I lose the FR and FL audio for 2ch sources. I get no audio whatsoever for native multi-channel audio supplied by HDMI sources when directly connected or passed through my switch box. The system also fails to provide test tones or any audio when trying to auto-configure the speakers using the supplied microphone. It does, however, have no problem supplying video through HDMI to the monitor when on HDMI or analog sources.
other information: I have a brand new 5.1 speaker setup. new speaker wire, new banana plugs on the cables, and everything is wired into the appropriate jacks on the receiver (including the sub which is for sure plugged into the pre-out sub line). so, it's all new except for the receiver. Each speaker has been tested using the somewhat working 2ch direct output, and they are all functional, and the sub was tested working using separate source than the receiver.
so, a little additional backstory, I work tech support in a school, and when we finished a round of classroom hardware upgrades where this unit was decommissioned in known working order. Since it was in good shape and pulled from a lightly used classroom it seemed to be a shame if this unit were to find itself in the great recycle bin in the sky. So I took it home. The receiver then sat on a shelf in my storage unit for about a year while I moved, twice, and found a reasonable set of speakers to use with it. When it was previously configured at the school it was primarily controlled via a Creston automation panel in the classroom that was connected to a control deck that I believe spoke to the receiver via the RS232 port. Unfortunately I can't give you any more information than this about the setup, but a part of me wonders if this might be related to my issue.
I suspect my problem is a configuration issue, but I don't really know at this point. I've scoured the menus on the receiver hoping to find a universal reset switch to set everything back to defaults, but if one exists I haven't found it and there doesn't appear to be one in the manual either. I've also pushed every button on the receiver at least a dozen times, and I've tried to scrub and manually adjust every possible menu item. Unfortunately it still seems that I'm coming up doughnuts when I go to find answers.
I am willing to accept that the unit might be broken, but I'd like to know before I decide to actually SPEND some money on a new receiver. Thanks a lot in advance for your help and advice.
