World Wide Stereo
Help me out guys! (1 Viewer)
DorianBryant
I have a serious sickness. I change receivers more than-well you know. I currently have a Yamaha RX-V640 (same as HTR-5660). I have it up for salein this forum. It just doesn't do it for me. I am using 2 prs of Paradigm mini-monitors, CC-370 center, and a DIY Shiva.
I picked up a HK-135from this site but doubt I will keep it- maybe for the workout room but don't think I will be satisfied.
I am considering the following:
possible deal for a Yamaha RX-V1400
Sony 1000ES or 2100ES
Pioneer Elite 52TX or even the 9100 from E-Bay(refurbs)
I would like to keep it around $400. Used and refurbs are my best value. I have tried the HK-235, Onkyo 602, panny XR55, Marantx 4200.
Anyway, what would you suggest for these Paradigm speakers in a 18'x20' room? Can't seem to decide...
I would like high power (for the price) and some type of room eq. Wondering some pros and cons you might be able to come up with or even new suggestions...
John S
Also look at the Yamaha 5890.
Look for some less expensive external amps as a possibility.
DorianBryant
I tried some amps with the 640 but it does not have a 12 volt trigger and my wife really didn't like dealing with the extra power buttons. I really need the room EQ. I did try the Pio 1014 and liked it but it did not work with my DN DVR. Now I have the 811 for HD but the 1014 and 1015 are hard to come buy.
John is the 5890 the same s the 1400? Or is that the 1500?
Garrett have you seen any of the Sony models? I did not see any on Flea-Bay. Can check Audiogon...
lee ison
I think the dn dvd will work, but you have to program the remote manually on the pioneer 1014, i could be wrong but, I'm pretty sure the op. manual can instruct you how to do it.
Garrett Lundy
Oh wait, nevermind... The TA E9000-ES pre-amps are in the $400 range, but the TA N9000-ES 5 channel amps are still like $700 (a little out of your range).
DorianBryant
The 640 is a nice receiver but I don't get its potential without really eaising the volume. My favorite receiver in this price range is the HK 235 but it did not sound good to me with Paradigm-laid back speaker with a laid back receiver.
There are Pioneer Elite 52tx and the 9100tx on the Bay for about $420 shipped-new but refurbed. Wondering how these may sound. Also considered the Sony 1000Es for about $300. Thoughts?
rob-h
Dont go with a Sony if you want the best sound and power for your money. If you can hit $520 or so shipped the Yamaha 5890 is a great deal. The Pioneer 1015 is also a hefty choice in your price range and cheaper.
John Garcia
NorCal
In a room that size, I think most of the receivers listed are going to struggle, except maybe the 630 and the 5890. I'd say look at the least expensive solution that sounds good in your price range and add a 2 or 3 channel amp for the front.
My room is 19 x 20 and smaller bookshelf speakers have a tough time filling it well.
Ralph B
hhhmmmmm,
I own a Onkyo 602 and Paradigm Monitor 7's and a CC-370 with sapphire surrounds and an SVS 25_31PC+ Sub and I love my setup!!!
SJeans123
