The reason I am using the subs in and out is because I don't want the low level for the sub going to my main speakers. And there is no "OFF" setting for the sub in the menu, only SUB yes or no.Why are you using the speaker in & out on the sub?
You should be using the line level input on the sub from the sub out on the receiver. Then turn on sub in the receiver and set the front speakers to SMALL. Set the crossover in the receiver to 80hz and turn the crossover all the way up on the subwoofer. Set the volume at 50% on the sub and start tweaking the receiver settings to the sound you want.
If you want to use the speaker in/out, you will have to turn off sub in receiver settings and make sure the front speakers are set to LARGE. On the back of the sub, set the crossover to 80hz to start and then tweak from there on the sub.
Greetings,On another note, do you know much about the avr3802 remote control? If you do, shoot me a message, and I will tell you about the problem, or maybe not a problem that I have with it. Thanks again, Don.
Thanks Edwin, but I think I figured out what to do with it.Greetings,
Most of the receivers I have used in my setup have been Yamaha. John Rice or one the others who have posted in here would be best to ask when it comes to Denon. John Rice and the others have quite a lot of experience with Denon products.
Hi John. I was having a hard time trying to get the remote to the AMP setting. It would be on say the CD setting, and I could not figure out how to get it back to AMP so I could use the on screen menu. But after reading the manual, I think I have figured it out. I will see if it works like it says in the manual. Fingers crossed Thanks for all your and everyone's help.You should post the possible problem with the remote here…
