World Wide Stereo
HDTV's by "LG"... thoughts? (1 Viewer)
Maul
Craig Kocher
I've been browsing some HDTV's by LG recently and was wondering if anyone has had any bad experience with them? They seem to be decently priced with good contrast and picture quality.... but I don't normally buy stuff outside of the realm of the usual name brands...
any thoughts?
Here is the model I'm looking at... LG 42" 1080p Flat-Panel LCD HDTV
Model: 42LB5D here are the specs according to best buy:
Product Features
16:9 widescreen aspect ratio and 6 selectable viewing modes deliver a cinema-style entertainment experience
3-2 pulldown for accurate reproduction of film-based movie sources
XD Engine combines 6 distinct processes that improve brightness, contrast, detail and color, as well as reduce signal noise for high resolution and cinema-like images
5 picture modes and 4 color temperature modes make it easy to enjoy a custom viewing experience
Black Stretcher extends black levels in bright scenes for enhanced picture contrast and detail
Super IPS technology reduces common distortion and blurring caused by fast-motion video
Intelligent Eye function adjusts brightness based on ambient light levels
3D digital comb filter delivers state-of-the-art detail and color enhancement
SRS TruSurround delivers a virtual surround sound experience through dual 10W speakers
Auto volume leveler prevents volume fluctuations and is ideal for night viewing
Ultraslim LCD measures 3-1/2" deep; comes with a table stand or can be mounted on a wall (with optional VESA mounting kit, not included)
PC video input lets you connect your computer to experience high-resolution images
Inputs: 1 RF (rear), 2 composite video (side, rear), 2 S-video (side, rear), 2 component video (rear), 3 HDMI (rear), 1 PC (rear), 1 PC audio (rear), 1 USB (side)
Outputs: 1 audio (rear), 1 coaxial digital audio (rear), 1 optical digital audio (rear)
V-Chip parental controls keep children from being exposed to undesirable material
ENERGY STAR compliance assures a high standard of energy efficiency
Other convenient features include closed captioning, manual clock, favorite channel and sleep timer functions
What's in the box: 42" 1080p flat-panel LCD HDTV, table stand and universal remote
Product Details
Warranty Terms - Parts 1 year
Warranty Terms - Labor 1 year
Product Height 29-3/5" with stand (27-1/10" without)
Product Width 40-3/5"
Product Weight 60.6 lbs. with stand (50.7 lbs. without)
Product Depth 11-9/10" with stand (3-3/5" without)
TV Type LCD flat panel
Screen Size 42"
Aspect Ratio 16:9
Display Type Flat-panel LCD
Built-In_DVR No
Digital Cable Ready No
Digital Capabilities HDTV with QAM tuner
Maximum Resolution 1920 x 1080
Vertical Scanning Lines (Native Mode) 1080
Contrast Ratio 10,000:1
Brightness 500 cd/m²
Comb Filter 3D digital
USB Slot Yes
Digital Convergence Yes
HDMI Inputs 3
DVI Inputs No
S-Video Inputs 2
Component Video Inputs 2
Composite Inputs 2
PC Inputs 1
RF Antenna Input 1
Audio Outputs 3
Watts/Channel 10
Speakers 2
Simulated Surround Yes
Sound Leveler Yes
Language Options English, French, Spanish
V-Chip Yes
Sleep/Alarm Timer Yes
Remote Control Type Universal
If I'm posting this in the wrong place, please re-direct me!
-Craig
728x90
Mort Corey
Probably as good or better than any of the Korean competition, but I just can't get past that they are still Lucky Goldstar despite the new logo. LG seems to have parts/service availability problems across their product lines from what I've read recently. I was looking at their laundry offerings recently and the specs were really nice on their products. I picked, at random, three or four repair places from the local yellow pages and called and asked if the worked on these machines......NONE would. I purchased another product. Just my two cents.
Mort
Jesse Skeen
Not too familiar with their TVs, but they own what's left of Zenith. I'd buy an HD ChromaColor set if they put one out! :)
(How bout a System 3 with Space Command?)
Gary Shipley
If I were you, I'd take a look at the Panasonics. I purchased a 50" Panasonic plasma about a year ago. I compared the picture quality of it to an LG as well as a Samsung. The picture on the Panasonic was much sharper in my opinion. The LG and Samsung pictures seemed to have a "soft" look to them. If at all possible, do a side by side comparison and see what you think. The best advice I can give you is research each over and over before you decide which direction to go. Good luck!!
Sitcomguy
