RichardnVA
- Jun 27, 2010
- Richard
Would appreciate your help with a problem I'm having with my home theater.
First, here's my setup:
HDTV fed via HDMI from a Yamaha Home Theater Receiver (RX-V3800) to a wall mounted Panasonic Plasma TV (54" G20). All my video sources (DVR, PS3, DVD) feed into the Yamaha and then I have a HDMI 35' in wall "home run" cable to the TV.
We had an electrical storm that knocked out quite a few electronics in the house, among them my 50" Panasonic plasma TV. Upon closer examination the TV still works, but the HDMI input was dead. I hooked up a smaller 17" Zenith LCD to the HDMI cable and was able to get a picture on it, so I assumed the HDMI port on the Plasma was dead. The on-screen menu still worked and I was able to get the other inputs (component and composite) to work. I got an authorized Panasonic TV repairmain and he couldn't fix the plasma, Panasonic no longer makes the needed DG board to fix the HDMI port. So I buy another Panasonic Plasma. Hook it up and... no picture! On screen menu works (just like my damaged TV) so I try different inputs and I'm able to get a picture. So I test the HDMI cable with the smaller LCD tv again, and I get a picture on the LCD. So I keep trouble shooting and try bypassing the Receiver and plug my PS3 directly into the TV via HDMI, and I get a picture. Try the same thing with my DVR and I get a picture, so I think it must be the HDMI out jack on my Receiver, but when I plug the smaller TV into the HDMI out on the receiver I get a picture. Could the HDMI jack be "partially" damaged? Is there some type of power sensitivity in the HDMI circuitry? I believe a couple of the pins in the HDMI cable are powered, could this be an issue? As I mentioned above the HDMI "home run" cable is 35' long. The cable works as I've tried it on several different components, but it doesn't work when hooked up to the Yamaha Receiver. I would think that because it's a digital connection that if it was damaged, I wouldn't get any signal at all, but I get a signal when hooking the 17" LCD into the Receiver HDMI port. Could it be an issue with the 1080p signal that the Panasonic needs? The LCD TV is not 1080p. Any thoughts on this would be greatly appreciated. Thanks
