FS: XGA DLP Micro projector (about 3.0 lbs) (1 Viewer)
AndyWK
Hi all,
I have a Compaq XGA projector for home theater for about 9 months and my wife ask me to replace it with Direct View Tubes.... (the reason is that the image is too big - I have it on a 25x25 room so that image is over 140 inches).
So here it is and I have to let go of it. I'm trying to get about $1200 for it (just have a new bulb and still have warranty until July).
Compaq iPaq MP2800 Projector
- Still under Compaq warranty until July 6
- Brightness: 1100 lumens (average), 1500 lumens (peak)
- New lamp - under 50 hrs (1500 hrs rated)
- Contrast ratio 400:1
- Native XGA (1024x768). Automatically scales up from VGA - and SVGA or down from SXGA. Also scales to Macintosh
832x624 format VGA, SVGA, XGA and SXGA compatible
- Lens type: Adjustable focal length zoom lens (1.2x) and
manual adjustable focus
- HDTV support (DVI input): 480i/p, 720p, 1080i
- Weight: 3.0 lbs
- Size/volume (HxWxD): 7.11x2.71x8.71in.
- Standard VGA, DVI inputs
(optional Media adapter, cable, remote not included)
If you need any extra info, please email me anytime! If you are close by, I'm happy to demo to you.
Thanks for your time,
Andy
mycuu
