FS:SONY BRAVIA KDL46XBR3, 1080P FULL HIGH DEF LCD TELEVISION (1 Viewer)
arsh
Description
PRISTINE, OCCASIONALLY USED ONLY. BEAUTIFUL PIANO BLACK FINISH.
$2499 or BO
Technical Details
* Includes - Remote Control (RM-YD010), 2x AA Battery, HD-15 to HD-15 Cable, Operating Instructions, Quick Setup Guide
* 16 - 9 1080p HD Resolution Panel
* Display Resolution - 1920 x 1080
* BRAVIA Engine PRO Video Processor
* Live Color Creation System featuring WCG-CCFL backlight
Technical Details
* Brand Name: Sony
* Model: KDL-46XBR3
* Display Technology: TFT active matrix
* Display Size: 46 inches
* Image Aspect Ratio: 16:9
* is_hdtv_compatible: Y
* speakers_included_description: 2 speakers
* Height: 22.0 inches
* Width: 32.0 inches
* Depth: 13 inches
* Weight: 29.0 pounds
Product Description
Product Description
Presenting the next evolution of the BRAVIA Engine PRO. Sony improved on the great benefits of the BRAVIA Engine by adding a picture quality enhancement circuit called Digital Reality Creation(TM) Multi-function v2.5. Add to this the crisp details, outstanding Contrast, eye popping colors and dramatically reduced Digital artifacts. With Sony BRAVIA XBR(R) HDTVs, Full HD 1080 means 1920 x 1080 Pixels and 1080p video inputs. Full HD 1920 x 1080 panel Resolution with over 2 million Pixels (more than twice that of 720p HDTV) is exactly what you need to reproduce the 1080p content that can be delivered by our cutting edge 1080p Blu-ray Disc player. Uncompromised picture quality starts with combining carefully chosen components and circuits to optimize system quality, among these are the color creation and processing functions. Designed for maximum versatility, Sony's BRAVIA XBR-Series LCD TVs are equipped with a comprehensive range of input interfaces. The HDMI (High-Definition Multimedia Interface) is the first industry-supported, uncompressed, all-Digital audio/video interface. The PC input (HD-15-pin) offers easy connection to your PC, allowing you to use your high Resolution BRAVIA XBR-Series Digital TV as a computer monitor. ATSC Digital Tuner with unscrambled Digital cable (QAM) capability 3x HDMI (High Definition Multimedia Interface) Popular Floating Glass Design Digital Amplifier SRS TruSurround XT BBE Digital Audio Enhancement Technology Analog Audio Inputs - 5 (1 Side / 4 Rear) Variable & Fixed Audio Out - 1 (Rear) Component Video (Y/Pb/Pr) Inputs - 2 (Rear) Composite Video Inputs - 3 (1 Side / 2 Rear) Digital Audio Output - 1 (Rear) S-Video Input - 1 (Rear) Headphone Output - 1 (Side) PC Video Input - 1 (Rear) Energy Star Compliant Sleep timer - 15, 30, 45, 60, 90, Off 3D Digital Comb Filter DRC MultiFunction Circuitry - DRC(TM) MF V2.5 Display Technology - 17
** ALL ORIGINAL ACCESSORIES, OWNER MANUALS, REMOTE.
LOCAL PICK UP AVAILABLE! PAYPAL ACCEPTED, TAKING OFFERS!
arsh
I am sorry! I did not mean to not price it, just an honest omissional mistake, will correct it.
thanks for pointing it out.
mycuu
