Wayde_R
- Aug 25, 2003
Been looking at a couple of players. The expensive Marantz dv8400 and the much cheaper alternative, Pioneer DV-563A.
I read somewhere that a regular digital out isn't capable of passing the high res sound of five channels so a higher bandwidth alternative is required such as firewire. Both units feature digital outputs as well as separate 5.1 channel outputs. I assumed you'd want to use the 5.1 channel outs for high res 5ch sound as the only option now I'm a little confused.
My receiver is an ArcamAVR200 which has 5.1 ch inputs. Would I be better off using the 5.1 ch inputs for a more true rendition of dvdaudio? Does the digital outputs somehow 'cheat' or compress the sound in an undesirable way? Are the 5.1 outputs even capable of passing the hi res audio signal through it? This would make both units kind of useless.
Any advice or explanations would be appreciated.
Wayde
Wayde
