Dude
- May 19, 2011
- Alex Fleetwood
Ok, so I thought I would give myself a fun summer project and work on building a sweet sound system for my dorm room, boombox-style. I have two sets of Logitech Z-2300 speakers that are going into this project. The goal is to wire everything into a single enclosure, with volume/bass dials and a headphone jack.
2 8" subwoofers
4 ~3" side speaker cones
1 control unit (I lost one from the second set) that controls volume and bass, and has a headphone jack
and the guts of both subwoofer enclosures.
One subwoofer is nonfunctional, but I believe it to be a blown fuse. (Actually, I don't know for sure, I'm just hoping, but as it failed quietly and not spectacularly, that's my best guess.)
After taking one set apart, I realized that I have no clue what's going on on the insides of the speakers, and that's where I need some help.
http://i106.photobucket.com/albums/m273/McC4rtn3y/DSCF3999.jpg
1. black wire
2. red wire
3. speaker jack for side speaker
4. speaker cone apparatus from side speaker
http://i106.photobucket.com/albums/m273/McC4rtn3y/DSCF3998.jpg
A. connects to Z, sends inputs to entire system
B. Headphone Jack
C. Volume/Bass controller
http://i106.photobucket.com/albums/m273/McC4rtn3y/DSCF3997.jpg
X. Subwoofer cone apparatus
Y. not 100% on this, but it has tons of coils of copper wire so it has to be something that adjusts voltage/current from the wall socket to the speakers. Guessing that it steps down voltage and steps up current.
http://i106.photobucket.com/albums/m273/McC4rtn3y/DSCF3996.jpg
This is where I run into trouble because there's so much stuff going on. What is the square thing on the bottom right? what do the two black cylinders in the middle do? The control board looks confusing but I figure if I cannibalize the whole thing i won't need to know too much.
H. Heatsink on the back of the metal panel.
P. power cord out. Im probably going to use two plugs to power the whole thing, and just try to split the inputs to both sets of speakers at the same time.
F. Fuse, haven't looked at it yet. may need to be replaced.
S. On/Off switch
Z. behind the little "c" of green wire is where the control cable plugs in to the speaker set. This is my biggest problem. I only have one plug, and I'm not sure how could split out from there because it goes right into the control board.
I. This is where the side speakers plug in.
So...where do I go from here? I'm not worried about building the enclosure itself, as that won't be a problem. I just need to figure out how to combine the two sets to run at once with a single input, and have it actually work.
2 8" subwoofers
1. black wire
2. red wire
B. Headphone Jack
S. On/Off switch
