Rob Varto
- Mar 5, 2000
Title says it all. While the cord is pretty long, it doesn't quite cut it for my setup. I've looked everywhere and had no luck finding one. Does it even exist?
COMING SOON: May 2002
900Mhz Wireless Premium Controller ::
You can perform your victory dance up to 40 feet from your Xbox. The Mad Catz 900 MHz Wireless Premium Control Pad unplugs you from the console even as it gives you all the superior control you demand. Features include rubberized grips to reduce fatigue and improve handling, dual analog joysticks, fully analog pressure-sensitive action buttons and D-pad, macro programmability for complex moves and intense vibration capability that lets you feel the action. Eight discreet communication channels mean you can't be blocked; a charging dock stores the controller and recharges your batteries at the same time.
MSRP:: $59.99
Features:
900Mhz controller with 8 discreet communication channels
Built in recharge battery with docking/recharge station.
Fully analog: 6 analog buttons, 2 analog triggers.
Intense vibration feedback
Advanced macro function
