I'm in the planning stages of building an HTPC, which is easy for me because I'm a PC technician, but only in the planning stages because I am currently broke as the proverbial joke.
In any event, I wanted to see some pictures of the HTPCs some of you have built.
What case did you go with? what hardware did you decide to use? What do you use YOUR machine for mostly? What kind of system do you have it hooked up to? What HDTV tuner, if any, did you use and how do you feel about it? What solution to general video out without being forced to use a crappy S-Video output did you use?
Style points can be awarded, do you have a crazy mod? is your HTPC made from a nerf football? How about a replica of R2-D2? Did you use a HTPC case that looks like a HT component, or did you build your own case? Did you silly light it out?
And of course don't forget, pictures, pictures, pictures.
Lets hear some war stories.
