I recently bought a Epson Home Cinema 4010 3LCD Home Theatre Projector for my home theater. It's mounted on the ceiling and connected to an Onkyo TX-SR607 A/V unit via BlueRigger in-Wall High Speed HDMI Cable - 35 Feet (10 M) - CL3 Rated - Supports 4K@30Hz, Ultra HD, 3D, 1080p, Ethernet and Audio Return.
At first there were no issues however and all was good for about 3 weeks but then about 2 weeks ago for no reason, when you power up everything, there is no signal on the screen. About 7 minutes later, the signal appears and all is good.
I have tested this setup (Cable, A/V unit) with our old Viewsonic projector and this does not occur. I then tested the New projector (Epson) and A/V unit with a different HDMI cable and the same thing occurred.
What would cause this sudden delay to occur?
Is it a defective projector?
Is there a setting i have not looked at on the Epson?
Is it a compatibility issue with the A/V unit?
Any other suggestions on a possible culprit?
