Dustin B
- Mar 10, 2001
Each port should be 19.5" long.
The MDF usually goes for a little over $30CDN per 4x8 sheet. You should be able to find 4" PVC pipe at the same place you buy the MDF. Should be sold by the foot and be pretty cheap. And the rest of the little things do add up pretty quickly though. Are you building the SBB4 box plan, or are you doing a sonotube? Either way I don't think $85CDN will quite enough to get everything you need to build the enclosure.
