mcd278
- Jan 7, 2007
- Jake McD
Good afternoon, all. I have a 50" Panasonic TH-50PX60U plasma HDTV and a Panasonic SC-HT740 HTiB (1000W 5.1-Ch. Home Theater in Box). HDMI cables connect the digital cable box to the TV and the TV to the 5-disc home theater receiver. Per the operating manual, which I could very well be misinterpreting, stereo audio cable also connect the TV to the receiver. My problem is that I can't get sound from the TV to play through the home theater speakers.
I get sound through the home theater speakers when I play DVDs and CDs, so it seems the speakers are hooked up correctly. I've also turned the TV speakers both off and to their minimum level to see if which way sound was controlled but got nothing. I've been perusing the operating manuals for the TV and HTiB and it appears my issue could be that my TV does not recognize that the HTiB is connected. On page 23 of the operating manual it states that "'Home theater' with speaker icon appears" on the TV menu screen "when a Panasonic 'Control with HDMI' home theater system is connected via the HDMI input". As stated above, the system is connected via the HDMI input, and 'Control with HDMI" is set to 'On' in the TV menu. However, I do not get a 'Home theater' with speaker icon on the TV menu screen. Instead, I get the standard Picture/Audio/Timer/Lock, etc. menu. So I am at a loss. I should note that the home theater receiver- perhaps obviously- also does not recognize that the TV is connected. I do not get a 'TV' when option when pressing the 'AUX' button.
I would greatly appreciate any guidance. Thanks in advance for your time and assistance.
Jake
Jake
