Josh Lowe
- Jun 19, 2002
The simple fact is, most people still haven't even heard of the formats.And it's no wonder. I stopped by Best Buy today to use a 10% discount on music coupon and hopefully add a couple of SACDs to my collection (I upgraded to a SACD/CD player a couple of weeks ago). Well, they only had a handful of titles, and they were tucked away next to the DVD players, on the complete opposite side of the store from the rest of the music CDs.
I ended up only buying The Rolling Stones: Hot Rocks, which was located in the regular music section. However, this title has absolutely no labelling to indicate that it is a hybrid SACD/CD, so very people would even realize this was a SACD disc.
I'm not sure about your Best Buy, but my local ones have a bigger selection of DVD-Audio and SACD titles actually in the dvd department.Greg,
All three Best Buys in my area do have a small selection of DVD-Audio and DTS CDs in the DVD-Video section. However, they are stuffed on a bottom shelf, where you have to get down on your hands and knees just to look through the titles. There are no SACD titles in this section -- there are only a handful of SACD titles tucked away in the DVD/CD hardware section of the stores.
Luckily, I discovered that the local Dearborn Music store within walking distance of where I work has a bin with DVD-Audio and SACD titles, and they were marked at a 20% discount. That makes them competitive with the online prices I've seen, and they had a decent selection of titles.
1) I think the whole copy-protection issue is bogus on this high-end audio formats. If you are going to invest in DVD-A/SACD formats, its obviously for sound quality reasons, putting it on MP3 and playing it in your car would be...for lack of a better word, RETARDED. I am fine with the record companies copy-protecting them anyways, just for preventive reasons. Anyone who wants to turn their HIGH RESOLUTION audio discs into MP3's should be slapped. That's sac-religious.
I find the copy protection to be an excellent reason to avoid both formats. Just because a car or portable player or computer might not be as high-resolution as your main stereo system does not imply that you only want to listen to music in one place.
I for one do not feel like buying multiple copies of the same prerecorded album in multiple prerecorded formats just to enrich the coffers of a record label that's deliberately taking steps to cripple their products.
The whole bit about not being able to pull music into a computer to make compilations is another drawback.
Finally, I don't care for having vendors treat me like a criminal. Funny how that makes me close my wallet.
Rife with misinformationI must have missed all that "misinformation", the article seems right on the mark to me.
Doesn't the Pioneer 49TXi/47Ai combo get full digital out?
And Denon digital link?
And Meridian?
Any more to come?
Exactly, but apparently "there's no misinformation" in the article. Not to mention the whole J6P tone of "they're not user friendly", give me a f'n break. How difficult is it to put a disc in and press play?
What am I missing here? The Toshiba 4800 is a DVD-A player that has the 5.1 analog outputs and it has an opticl digital output. The specs on it do say that the digital out isn't at full strength, Mhz or something, whatever. Sorry I don't remember the technical term they used. But it does have a digital out that can be used on DVD-A. So who says they don't have digital out for these?The Toshiba (and just about every other brand) players will not send DVD-Audio or SACD signals through their digital audio outputs. You must use the 5.1 analog outputs on these players for those audio formats. The digital connections only support Dolby Digital, DTS and PCM signals.
Not to mention the whole J6P tone of "they're not user friendly", give me a f'n break. How difficult is it to put a disc in and press play?My impression was that this isn't always the case. I can't remember which titles, but I remember when auditioning some DVD-A discs a while back that some go by the DVD-Video style. Not a simple insert and press play thing, but more of an insert, select the audio format, then press "enter" (not "play").
