Darren_T
- Oct 1, 2001
Hi,
I posted earlier about which Paradigm speakers I should consider upgrading to, no responses yet but I've recently auditioned a bunch of Paradigm and B&W speakers and am thinking I might switch to B&W. If I make the switch I will probably need a new sub. I currently have a Velodyne CT-100. It performs pretty well in my small 12' X 15' Room but I want more punch. I'm really out of the loop, just starting to catch back up again and am trying to stay within a tight budget. I'd like to spend 700 or less on a sub.
I have a 5.1 system with an Onkyo TX-DS777 AV Receiver.
The B&W's I'm considering are:
Fronts - DM604 S3
Center - LCR 600 S3
Surrounds - DM601 S3
Possible sub is the ASW 650 but I haven't auditioned any subs yet. Anyone have a recommendation within my $700 budget for a good musical and HT sub? I might just keep the Velodyne for a while and think about it. My ratio is probably 75% home theater - 25% music but that could change with better speakers.
Thanks for any advice on the sub and comments on my B&W selection. Let me know if there are better matches for surrounds or any other advice you might have. I'm still learning the new models.
Darren
Fronts - DM604 S3
Center - LCR 600 S3
Darren
