Can I get some DVD player reccomendations (1 Viewer)
Rob T
I currently have a Toshiba SD-1600, which is a ffairly cheap player. It doesn't read any 5.1 tracks. Just the surround ound and mono tracks, I think. The video is decent, though.
I want to get a good multi-disc player that can read the DD and DTS 5.1 and I'm hoping to get one for $300-$400 CAN. I have seen a few in The Future Shop that look good, especially a Panasonic 5-disc player for $349.99 CAN, but I'm hoping that there are other better choices out there.
So could I get some suggestions?
I probably won't be buying this till August or September (it'll definitely be bought before B5 season 1 comes out), but I'd like to start figuring out what player I want now. :)
Lee Petty
are you looking for something with built in dd and dts decoding? if not, sony makes a 5 disk prog scan dvd player reasonably priced at $250.
check it out here
Rob T
Actually, I think that's the one that I saw at The Future Shop. :laugh:
if it can play the DD & DTS 5.1 tracks then I'll take it. :)
papill6n
