Jeff_Jergerian
- Sep 15, 2001
I’ve found this forum to be an excellent resource to learn about the topic of building a dedicated home theater. I’m in the process of having a room finished in my basement, which will be used exclusively as a home theater room. The theater portion of the room is about 20 feet deep and 12 feet wide, with 9 foot ceilings and no windows. I plan to use a front projector, with a 7 or 8 foot wide screen (16:9). I am having all of the construction done by professionals (walls, carpet, ceiling, electrical). However, I am going to run all of the home theater cabling myself. Before I begin, I have some basic questions that I’m hoping I can get answered here. Hopefully I ask these questions in a way that makes sense…..(I apologize in advance for the length of this. Feel free to e-mail me privately or post your answers here).
Is there anything in particular that I should keep in mind when running speaker wire through the walls? I plan to use wall plate terminals located behind each of the front three speakers. Do the wall plates need to be backed by a box behind the wall, or is it OK to just anchor these right into the cut drywall?
What recommendations can anyone provide for component cables to go the projector (ceiling)? I’m guessing that I’ll need cables that are around 40 feet. I plan to run two sets--one for Prog DVD now, and a set that is in place for a future upgrade to a HD DirecTV tuner. I’m assuming that I don’t want to use wall plates for these cable runs, and that I should just run them directly from the source to the projector. I’d like any thoughts on how to finish off the wall so it doesn’t just look like a ragged hole with cables coming out of it (both on the ceiling and behind my equipment rack). FYI: My equipment will all be hidden in a closet, but I still want it to look somewhat professional.
On the topic of component cables, I’ve noticed that some projectors offer two sets of HD inputs, but that one of them is BNC (or even a 15-pin connection). How do you connect a second component source to this type of input? Since the component cables have three ends, and the BNC has 5 ends, how do these two ends match up? Or am I going down the wrong road with this question?
I will need to use an infrared repeater system to distribute the remote signals. I know very little about this (other than what I’ve read on Niles product boxes and the Xantech website). It seems like a fairly straightforward setup to use mini IR blasters for this process. Is there anything in particular I should know before proceeding? I plan to put the receiver “eye” in the front of the room below the screen, with mini stick-on blasters over the IR windows of each of my components (including the projector and remote-control light dimmers). What type of cable is best to use, considering the supplied cables won’t be long enough to reach the dimmers and projector from the spot where I plan to have the control unit.
Is there anything special that I should do in the ceiling from a structural standpoint before it is finished off (to accommodate the projector)? I will be going with a lighter weight model, such as the Sanyo PLV60HT or the Sony 11HT. Even though it will be relatively light, I’m not sure if it is safe to just mount it right to the drywall in the ceiling. I’m not totally sure which model I’ll be going with yet, but I’m estimating a throw distance of about 11-12 feet for the dimensions I’m working with. Is there any advantage to building a drop down shelf for the projector instead of going with a pre-fab mounting bracket?
I’m sure I’ll have other questions as this project progresses. For now, these are the major ones that have been on my mind. I’ve searched through a number of topics to get me to this point, so I apologize if I’m asking questions that have been covered already. I’d appreciate any other feedback or suggestions to make this go as smoothly as possible. Experience is the best teacher, so let your experience guide me down this path
