James Gurney
Grip
- Aug 31, 2004
Hi folks, I'm planning to build a riser for my rear row of seating, and I'm looking for suggestions. A few searches seem to indicate several people have built risers, but I wasn't able to find specifics.
Anyway, the idea I have in my head is to use 2x10 topped with 3/4" ply. The 2x10 would run all around the outside, and also cross brace about every 18", so the frame will look kind of like this from above: (some imagination required):
__ __ __ __
|__|__|__|__|
I'm a little worried that a fully loaded couch could have as much as 600lbs of people sitting on it. Is 3/4" ply sufficient to support that much weight? The couch has 4 feet, each of which would not have direct support from the 2x10 underneath.
To address this, I was thinking I might add 2x4 bracing as well, so it would look something like this :
__ __ __ __
|__|__|__|__|
|__|__|__|__|
|__|__|__|__|
Is this overkill? I worry that maybe I'm overdoing things a bit and it's going to end up weighing so much it's impossible to move it into the basement (the basement is finished, so I don't want to build it down there).
Also, since I plan to cover it with carpet, I'd like to route the corners to get a nice smooth turn, which will prevent the carpet from looking nasty as it turns to go down the side. The problem is, you can't really route plywood, so I'm thinking of somehow working an inch or so of mdf into the top corner, so I can easily mould it. Anyone have any comments on that idea?
Thanks in advance,
James
__ __ __ __
|__|__|__|__|
__ __ __ __
|__|__|__|__|
|__|__|__|__|
|__|__|__|__|
Thanks in advance,
James
