dman7
- Mar 27, 2011
- Doug Svuba
I know I am a super newb, and everybody has a budget projector project, but I would appreciate feedback on my half-baked project ideas.
This may redefine the concept of budget projector project. I am OK with a bit older tech, and I am okay taking a little risk with ebay items.
I will have a small room (10' x 12') with very low ambient light. I was considering a used DLP tv about 65" wich can be had for around $350-$400 on craigslist, but now I am thinking projecter may be better. I want it to look good, but am okay with non-1080P since it appears that will save me a ton of cash. If I can get a native 720P projector with an HDMI input i think that may be perfect. would it be better to stick with the dlp tv? I could probably even find a reasonable 1080P unit?
From the limited research I have done so far I was thinking about a craigslist projector that is being offered for $200. it is the panasonic AE700u. I also noticed a few optomas on ebay for around $300 that may fit the bill...Optoma HD70, HD72, HD73.
I really have no idea about the screen, but once again budget is key. I am thinking 65"-90" because the room is quite small. I saw this on walmart.com.... Elite M80NWV for $70 ,,not opposed to trying paint either.
Am I on the right track?
Any other equipment suggestions?
What are the advantages/disadvantages of DLP vs LCD,
I am actually building the room in my garage, so I can incorporate speaker wires, mounting hardware, soundproofing etc, i can even change the size or shape a little bit if there is some reason for that.
.....How hard will it be to set this up?
Thank you for any help, and let the flames begin!!!
