budget DVD player- quick suggestions? (1 Viewer)
Jeff Bayne
hey guys, i need a simple dvd player- aiming for budget here. I'm going to buy it at sears, as I have a gift card, so here are my choices:
Sony 1-Disc DVD Player with Progressive Scan
DVP-NS57P/B
Toshiba 1-Disc DVD Player with Progressive Scan, Black
SD-4000
JVC 1-Disc DVD Player, Black
XV-N350B
Phillips. Its at the store, but not on the web- it was 49.99...
I fully realize this is cheap stuff compared to the stuff you guys run, but if you had to have one, which would it be?
Thanks a ton!
jeff
Philip Hamm
If it were my money I'd go for Toshiba or Sony. As much as I like Philips (I have had EXCEPTIONALLY good experience with their customer service and own much of their gear - they are a first call manufacturer at this price point IMO), I have had trouble with a budget Philips DVD player with scrathy rental discs. Sony and Toshiba seem to handle rentals better.
ericks
Erick
If I needed a "cheap" DVD player I'd probably buy a Toshiba HD-DVD player. I think the HD-A3 can be bought for just a bit over $100. I have an A2 (which I got for $99) which makes an excellent upscaling DVD player and has the side benefit of being able to play HD-DVDs:D .
DaveHo
The only problem with that is the speed. I'm looking for a cheap player for the kid's room, & since my wife & son will be the primary users, I'm not even considering the HD players simply because they are so slow to boot & load. In our main HT room, the slowness of the A2 isn't a big deal, but when you are trying to quick throw something in to appease a 3 yr old...
foster2292
