Bluesound is expanding its line of wireless multi-room streaming speakers with the $449 PULSE M, available now. Using Bluesound’s new ‘Omni-Hybrid’ design, the PULSE M has an angled, up-firing 5.25-inch woofer and two 0.75-inch tweeters offset at 45 degrees from each other. A custom-designed acoustic reflector above the woofer diffuses unwanted artifacts while directing the driver’s higher frequencies out and away from the speaker, creating “a 360° soundstage”, says Bluesound.
A DSP smart amplifier produces 80 watts of power with real-time monitoring and control of frequency bandwidth, dynamic range and distortion, making listening from any angle more engaging. The Omni-Hybrid architecture sits inside a manageable elliptical cabinet 8 (H) x 5 7/8 (D), and 6 3/4 (W) inches for space saving. There are also a wall mount accessory and adjustable floor stands if needed. The speaker is available in satin black or white finishes with an aesthetically...
Continue reading...
