WarrenBD
- Aug 9, 2000
- Warren
I’m hoping someone can put my mind at ease by possibly identifying what’s going on or at least postulating some theories.
My Panasonic 50” tv works fine, plays through my DirecTv DVR box no problems… everything is good. I bought a new Sony BDPS7200 Blu-Ray player and hooked it up to the decent quality HDMI cable my old Blu-Ray player used (had to replace it due to drive mechanism gone bad). Popped in a new-out-of-the-box disc and it played great for about 10 minutes, then the signal dropped out and I was looking at what I’d see on my tv if I’d switched inputs on the tv from DirecTv box (designated HDMI #1) to Blu-Ray player… a blank screen titled HDMI #2.
This drop-out lasted about 2 or 3 three seconds max, then picture and sound returned. Then the picture & sound dropped out again. And then returned. 2 seconds off, 2 seconds on, 2 seconds off, and so on. Tried another new disc, but still same problem.
Returned unit to Best Buy and replaced it with another (same model). Inserted another brand new disc and this time the player worked fine for about three hours and then – wouldn’t you know it – the exact same fault returned. I discovered if I powered down the player for a minute, then restarted, the fault would go away for about 10/15 minutes or so before returning, then it was back to the 2-second flopperoo. I set the input on the tv back to HDMI #1 and all other operation of tv & sat box remains absolutely fine.
I’ve no idea what might be causing this. Usually, if you lose sound & picture, they stay gone, but it seems reasonable to me that it’s the player and not anything else. Of course, there may be literally hundreds of you out there that might smack your collective foreheads and exclaim, “What a dummy! Doesn’t he know that etc. etc. etc. fill-in-blank causes that fault!!”
I’m not necessarily looking for the “EXACT” reason this is happening, after all, I’m going to be replacing the unit… happily, I have a protection warrantee… I just want to know what the hell might be causing it so I can have some techy ammunition in my back pocket if the customer service pod-person starts to give me a hard time.
I’d appreciate any thoughts on this. My thanks in advance!
