Karl D.
- Nov 8, 2004
Hi all, Im new here and hoping to learn some things as well as contribute where I can.
Has anyone out there heard of the owens corning basement finishing system? I am considering it to finish my basement but am unsure of its compatability with the home theater environment. One drawback I see right from the start is only one color is available. medium beige. However, the wall panels are contructed of compressed fiberglass insulation with an olefin fabric facing. The panels are "soft". The have about the same "give" as really stiff couch cushion.? They are said to absorb .95% noise. The panels go right up against the concrete walls with no vapor barrier as they are impervious to moisture, mold and mildew. The other problem I forsee is the drop ceiling. From much Ive read it may not be ideal for isolating the upper floors from below. It is awful expensive when compared to typical drywall finishing, but I never have to paint, 10 days to install complete, no dusty mess all over the house, if water does come in I dont need to repair the walls. Anyway, Ive gone on long enough. Im close to pulling the trigger and could really use some other perspectives. Thanks
