AVspec
OK, here is the info on the "WHINE" sound.
I used an IVIE IE-30A audio analyzer with an IE2P microphone. Now the peak noise seems to be around the 1.6k-2k (+-) range but does cover a full range of around 400Hz to 12.5KHz (+-).
The DB level seems to be about 11 higher then normal room level. My room level is about +-28db (yes the IVIE is that sensitive that it can even pickup sounds from outside of my house) and with the B&K Ref50 turn all the way up (+15.0 on the display) the noise level in the room went up to +-39db with the mic head 5 feet from the speaker.
Now just so people have a good understanding about the level of the “whine” and don’t go running all wild on the internet screaming: “THERE IS WHINE” , when the Ref50 is calibrated to the reference level of 75db, meaning I have the volume control on the Ref50 set to 0.0 and I calibrate to 75db, which with my setup I can either turn the gain on the amp down or turn the gain on the Ref50 down or both which is my case as turning the gain on the Ref50 all the way down to -12.0 does not get me down to the 75db Ref level, then the “Whine” noise does not register at all on the IE-30 analyzer and in fact I can not hear it even if I put my ear up to the speaker (this is a very important note here).
So as you can see from my testing, the only time, on my Ref50, that the “WHINE” is even detectable is when you have the Ref50 well above the 75db reference level.
So with this information in hand I called and talked to B&K tech support and had a nice long discussion about the “whine” issue (and of course my defective right front channel) and was informed that an adjustment can be made to the Ref50 to make the “whine” go away? Or maybe just less noticeable, and it was by adjust one of the gains on one of the internal circuits.
So after speaking with B&K, I believe the “gain” settings play a big factor along with speaker sensitive in this “whine” issue and I am starting to wonder if it is even an issue at all????
Why do some people hear it and others don’t? Well, I think it has to do with the amps and speakers that everyone is using. And I think to test this theory out we would need to swap B&K Ref50’s out between two systems, one that does not show any signs of this “whine” sound and one that does and see if it indeed then shows up on the Ref50 that did not have the “whine” before in the original system, and if it goes away on the Ref50 that had the “whine” in its original system.
So who wants to send me their B&K Ref50 that does not have the “whine” sound so I can test this theory out???
Seriously, if there is someone in my area that would like to try this let me know, or if anyone else out there can test this theory then that would be great.
Also I think we need to post which speakers we are all using along with the amps, and also the gain setting on both the amp(s) and the Ref50. Oh and lets not forget to mention if balanced or unbalanced connections are used.
My speakers:
JBL S36B Studio Series, 90dB Sensitivity (2.83v/1m), 8 Ohms.
JBL S-Center, 91dB Sensitivity (2.83v/1m), 8 Ohms.
Amps:
QSC EX800, Sensitivity: 1 Vrms @175watts (8 ohms), 20 Hz-20 Khz, 0.1% THD
QSC EX1200, Sensitivity: 1 Vrms @275watts (8 ohms), 20 Hz-20 Khz, 0.1% THD
Balanced interconnects.
Gain setting on Ref50: -11.5dB
Gain setting on QSC EX 1200 amp: -6dB
Gain setting on QSC EX 800 amp: -2dB
I hope this testing and information helps shed some light on this “WHINE”.
My speakers:
Amps:
