David Proud
- Jul 25, 2000
Hi! I have a Denon AVR-4800 THX EX Ultra certified receiver and am very pleased with it.
I moved into a new house and am building a new 7.1 "6 channel" dedicated theater with Barco 8" CRT front projection. I would like to add dedicated monoblock amps for my front two channels and setup the AVR-4800 to handle the side and back surrounds.
My question remains would the Denon AVR-4800 with the added monoblock amps be suffecient for a good EX/ES setup or is it time to upgrade.
How well is the Harmon Kardon 8000 and how does it compare to a Denon?
I know The Marmon Kardon has Logic7 but its not THX certified and I doubt the DACS in it are as good as the ones used in the AVR-4800.
I know my Denon was tested at 143watts per channel even though its rated at 125Watts a channel.
Bottom line is it worth selling the AVR-4800 and upgrading to the HArmon Kardon? Or would that be considered a downgrade?
David
David
