Aspect ratios and projectors (1 Viewer)
Stephen Bort
Hi, all, I'm new to the world of projectors, and I'm just curious as to what happens in the following situations. Assuming a 16:9 screen, please help me fill in the blanks:
1:1.78 animorphic: Fills the whole screen
1:1.78 non-animorphic: XXXXXX
1:2.35 animorphic: Fills the screen vertically with letterbox bars on top/bottom
1:2.35 non-animorphic: XXXXXX
1:1.85 animorphic: XXXXXXX
1:1.85 non-animorphic: XXXXXX
1:1.66 animorphic: XXXXXX
1:1.66 non-animorphic: XXXXXX
Thanks!
SimiA
Some of how the picture is displayed will depend on the units internal scaler, the STB you use, whether it has stretch mode, or you're watching an SD or HD signal, or DVD player your using, how the movie was shot etc....
Vb
Oupei
I have an infocus 5700, and I can only speak for my projector but here goes:
the display options I use the most on my projector are:
4:3 - interprets the picture as a 4x3 image, puts black bars on the sides
16:9 - interprets the picture as a 16x9 image, fills the entire screen
letterbox - interprets the picture as a 16x9 (or wider) image, cuts off the top and bottom of the image and displays the middle as a 16x9 image, filling the entire screen.
so for all the anamorphic ones, I'd use 16:9 and for all the non-anamorphic, I'd use the letterbox. You'd just lose a little bit from the top and bottom of the image with 1.66 letterbox (about 4% if my calculations are correct).
Ian-Fl
My projector has a zoom feature on it like most projectors. It's a 4:3 projector on a 16:9 screen. I used to watch DVD's set to whatever format it was in. I've decided more recently I don't care for blackbars on the top and bottom so now I zoom in the picture to fill the entire 16:9 screen. The picture is now big and I feel I'm not watching a slice even though I've lost some picture on the sides.
For 4:3 I hung my projector from a track used for pocket doors so I can slide the projector forward to view 4:3 within the 16:9 screen.
Nielmb
