Ascendo SV-12 Subwoofer has a flashing red power LED (1 Viewer)
Krümler
Rainer Zufall
Hi everyone,
I'm having some issues with a subwoofer not working, the Ascendo SV-12's 'Power' labeled LED is flashing in red.
I tested the cable and the amplifier, which seem to both not be the issue.
I can't find any information about the meaning of this red light, neither in the owner's manual nor the internet.
Does anybody here have an idea what the issue could be?
Edwin-S
Did you check the line fuse? it might be blown. The access to it is at the bottom of the power plug in on the sub.
Krümler
Rainer Zufall
Thank you for the suggestion,
I inspected the fuzes now visualy as well as with a multimeter and they seem to work fine.
I don't think they are the problem.
Nielmb
