Any ideas on image matching? (1 Viewer)
Casey H
Hey all,
I may have a problem. I am looking for a center and surrounds for my system. I currently have two Infinity SM152's:
S p e c i f i c a t i o n s
Frequency Response (+3dB) 44Hz - 25kHz
Crossover Frequencies 500Hz, 5500Hz
Efficiency (1w/1meter) 102dB
Power Rating 10-300 watts
Nominal Impedence 8 ohms
Woofer 15" (381 mm) polypropylene coated
Mid Range (2) 4-1/2" (114 mm)polypropylene coated
Tweeter 1" (25 mm) polycell "high-output"
My question is how to match imaging with the addition of a center and surrounds. Any ideas?
CaseyH
Bobby T
Whatever you get should be from Infinity. Speakers from the same line would be best. Or you could sell what you have and buy a complete 5.1 system.
Mike Kao
These sound like older models so if that's the case you probably will have trouble finding speakers from the same line. I would suggest taking a look at the interlude series... they should match fine!
papill6n
