I need a little advice. I am fairly certain the anti-glare coating on my 3-year old Sony KV-34XBR800 CRT is coming off. It seems to be wearing away mainly towards the bottom 1/4 of the screen, in the form of small (but numerous) smudges and vertical streaks. The smudges and streaks appear to be slowly expanding and proliferating, and a couple of them are quite large now... about dime size. These spots appear to be "silvery" compared to the rest of the screen.
I do clean the screen once every two weeks, using eye-glass cleaner (sparingly) and a soft cotton cloth. And I did make the mistake of using regular glass cleaner for the first few months of ownership, but the streaks and smudges have only appeared after 30 months or so.
In a search on this forum, I discovered that someone (with a similar problem) used a product called "Sprayway" to completely remove the anti-glare coating. Is this my only option ??? And are there any negative side effects to removing the anti-glare coating, other than increased reflections from the screen ??? Lastly, should I spend $50 to $60 for a service call, even if only to confirm that the anti-glare coating is indeed coming off ?
