BillBR
- Jan 21, 2006
- Bill. :)
Hi folks, I've done a lot of internet searching in the past hour, but can't seem to come up with a decent ballpark answer so I thought I'd poll you guys here. I had a skip scare earlier tonight when I was watching my BD copy of Vertigo (out of the Universal box) for the first time. There were no issues at all until about an hour and 45 minutes in, when Judy was writing a letter to Scottie. The disc skipped playback for about 6 seconds of the film. I instantly rewound and resumed playback to before the skip, and it did it again, at the exact same spot. I did that one more time, and again it skipped, then stopped the disc and looked at it in the bright light. There's a slight scratch on it, not very deep, probably received during packaging or shipping (I had only handled the disc once before, a month ago upon opening up the set). I used a cloth to wipe the surface of the disc (no cleaner liquid or anything additional) and popped it back in, went to the correct chapter, fast forwarded to the part that had been skipping...and then it played straight through, no problem, all the way to the end of the film. I then ejected the disc, put it back in again, went back to the same spot and it still played through without skipping. So! I'm a bit (well, a lot) anal retentive about these things and I wanted to know if A) it would be worth cleaning the disc with some cleaning solution anyway, just in case, B) what type of cleaning solution to use (some say window cleaner, others say a special liquid I'd have to buy online, one website said toothpaste!) or C) if I should just leave it alone and not make anything worse. I'm just interested to hear about any methods some of you may have that have worked for you, or certainly methods that didn't.
